Aug 4, 2021
33
London
DIY or Homeowner
I moved my boiler to the loft. I think it's 22mm pipes up there but they are close together and need lagging (they shouldn't be I know but oh well wrong tradesmen did the installation)
I'm looking for Armaflex 0.6mm thick 22m pipe borehole.
I'm not a regular DIYer but wanted to know if Armaflex and Kaiflex are roughly the same thing?
Armaflex (Armacell) don't do a 22mm thick 6mm. I've seen someone on FB market selling Kaiflex and they say it's the same thing but the texture looks different.
I kinda want the best but it need to be able to fix my piping
Self-seal or pre-cut too
(I've cleaned up the pipes since the picture)
Thanks in Advance
You could cut some chases out of a piece of Kingspan 😆
Never used kaiflex but 6mm of anything isn't going to do much for heatloss (might be good for condense on fridge pipes)
Reactions: ShaunCorbs
They are to close together to insulate individually it's not a good idea to wrap hot and cold pipes up together either ? , your choices are limited I'd lag the cold and form a insulated boxing to cover the whole lot , or you move em further apart. Kop
