ASHP or MAINS GAS?
View the thread, titled "ASHP or MAINS GAS?" which is posted in Gas Engineers Forum on UK Plumbers Forums.
From the Energy Saving Trust website.
What fuel will you be replacing? The system will pay for itself much more quickly if it's replacing an electricity or coal heating system. Heat pumps may not be the best option for homes using mains gas.
They all are if the customers expectations aren't set right. The move a lot of air and this constant'ish noise can be intrusive.
are you trying to tell me that gas boilers are totally silent if so why does my old worcester combi wake me up at night when the pump kicks in for no reason, at least with a heat pump they are outside and the noise is barely audible even when standing next to them
Clearly I'm not. 🙄
Btw, old says it all. Maybe time for a change to a ASHP? 😉
I am not going to read below because a really switched on associate of mine
who has vaste experience in the HVAC industry installed a ASHP in his sons house
really just to see ..........and he said to me last Sat that it was rubbish and a total
waste of time and money- his men would not have installed it incorrectly
Hi and thanks for reading my query
I am renovating an terraced Edwardian house which will be well insulated. The gas boiler is old and the entire Central Heating system is a mix of ugly rads, normal piping and microbore, in short it needs replacing.
I will be fitting UFH regardless of the ASHP/Gas question as I prefer it and the floor boards need lifting and insulation installed anyway.
We have a mains gas supply.
Is an Air Source Heat Pump a better choice than gas?
Steve
Heat pumps are only any good in new builds and we're gas is not available at the moment gas all the way. In a retro the insulation has to be to the maximum but it still wouldn't be worth it. A little air source heat pump is good for a conservatory as it can blow hot in the winer and cold i the summer
obviously it hasn't been installed correctly, they're probably just a bunch of pipe stranglers who haven't got a clue
If there so rubbish, why does my ASHP work so well and efficient, along with 1,000's of others? Your associate must have missed something along the way, a really expensive "just to see".
Fair play to all - perhaps my opinion because of my friends experience is premature.
We will get the system rated and compared and report back on this forum in due
course.
Thanks 4 all your input
You are extremely misguided. I suggest you fit a few in very differing situations before making comments that make you look more than silly.
Rip off Britain was on last night on bbc 1!
It featured a whole new build housing estate with NIBE heat pumps that were supposed to be cheap to run! Long story short, they were costing a massive amount to run in electric usage!!! The tenants could not afford to turn them on!
They were all ripped out & gas boilers fitted! Everyone's happy again...
BBC News - 'Efficient' heating system left families with big bills
There was a lot of complaints up & down the country about these systems... I don't think they live up to there claims!
On another perspective, in years to come who is going to maintain these things? They will defs be a lot more to repair than your average gas boiler! How much to replace a compressor on those big outside noisy units?
This program was on last year, they were incorrectly specified by the house builder and incorrectly operated by the householder.
Its different from a Gas boiler as anyone with half a brain can fire in an oversized boiler and it doesn't affect the energy bills as much.
You need to be trained in the installation, design and limits of operation of Heat Pumps.
The technology has been around for years within the air conditioning industry so to try and say this technology doesn't work just isn't the case. What does need to happen is that installers, householders and the general public need educated on this technology, instead of being fed gossip and horror stories of badly designed and installed cases.
I have a Nibe fighter 11 kw ASHP in a 160 sq metre house with overlay ufch throughout, also 1.75 kw peak pv system. Last quarter bill for electric for heat, cooking, lighting, tv etc etc £300.
It is comparable with gas in running costs if not cheaper. I have also blocked the immersion to let the heat pump run flat out.
All in all works very well with minimal maintenance
QUOTE>On another perspective, in years to come who is going to maintain these things? They will defs be a lot more to repair than your average gas boiler! How much to replace a compressor on those big outside noisy units?
Yes you are absolutely correct. The compressors are very expensive, but they are extremely reliable and will most likley last longer than a gas boiler. I don't know where all this noise issue comes from. Ok. If you have mains gas and live in a built up area, then a gas boiler is probably a sensible option. When there is no mains gas and don't have to squeeze the unit in somewhere inapropriate the ASHP is a good sound solution. They must be used differently to a gas boiler, but the benefits are very good. Its all about understanding the limitations and how they work.
Issue with nibe is house builders just built in 6kw immersion heaters as heating cost, then it kicks in costing huge amounts
At the moment, I would stick with mains gas. ASHPs don't really financially add up when compared to natural gas at the moment
I'd go with gas and when your boilers kn-ackered in 5 years time go for an ashp they'll be even more efficient then
If you're on mains gas it'd be mains gas for me over an ASHP sadly, for the following:
1- More costly per kW/h output compared to mains gas.
2- Even at 3.5 COP the CO2 out per kW/h is hight from ans ASHP at the moment due to power production being so dirty and transmission losses so high (up to 90% in some remote areas!!)
3- More expensive upfront for the ASHP compared to a gas boiler.
4- With the new standardised energy tariffs on there way in, unless the gas supply is totally disconnected, you will be liable for a standing charge anyway, even if it is used for cooking only...
Just my take on it... I struggle to make them stack up when anyone's on mains gas at the minute (and I'm a biomass engineer so favour renewables!)
Got one to do, I'm looking at hybrid it, so hw is off gas boiled and all heating on heat pump, then if ever needed gas can kick in. Works well, will be very good as he has 4kw pv, lad I met at Samsung other week said his 4kw pv pretty much powered his 9kw ashp for whole of April which is impressive
Ill add I've got a 16kw Samsung at my house now, 1975 4 bed detached all rads, ive specced rads for 45c as it works out £90 a year better than 50c so was worth tiny outlay. Double glazed and insulated 20 years ago, loft too. I'm actually logging it with Samsung as a trial unit. I've got a separate elec meter that is reading everything on heating side ie ashp, immersion, controls, pumps the lot. I'm saving daily data and its looking great against the oil I had when I moved in 2 months ago, I'm posting most of results on twitter page @kfiskplumbing and Facebook page Kfiskplumbingandheating.com so if interested take a look. At least I can give actual real time results. Cost to heat my house yesterday inc hw was 69p, day before 78p 😉
Reply to the thread, titled "ASHP or MAINS GAS?" which is posted in Gas Engineers Forum on Plumbers Forums.
Steve Williams,
eaton,
