Classic one is the new ones 18th am3 I think, if poly / plastic incoming yours doesn’t require to have sup bonding where as ours stat you must 😀
This day and age you would think they would get together and have a meeting
AMD 2
Yes, hopeless isn’t it
The muppets come up with electrical changes to justify new books, exams etc and they can’t even check they are understandable or logical. And they rarely correct earlier mistakes or errors.
With the 18th edition, the printed version was slightly different to the electronic version😁
The only opening in a built in gas meter box should be the outlet pipework spigot which must be fitted with the spigot adaptor to form a conduit through the cavity. Earthing should preferably be attached to the gas pipe immediately inside the property and the spigot sealed with non setting compound. No other holes are permitted in the box. The reason why of course is that such holes would permit gas leakage from within the box to enter the wall cavity.
N
N
