automatic air release valve
View the thread, titled "automatic air release valve" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Got called out - customer complaining no hot water but rads all hot. Turned up thermostat on boiler , pump up to max and closed all rads except for one. Water starting to heat in hot water cylinder but very slow. Whilst in attic I noticed there is no vent over the header tank - only an automatic air release valve on which the schrader valve seems knackered. Is it satisfactory to replace the air release valve or should I run a vent over the header tank. I may need to replace the HWC if water does not heat satisfactorily but that's another issue....
thanks
dave
There isn't a schraeder valve on an AAV. There's a valve cap but it's a needle valve under it operated by a float. The valve cap may have been shut because the AAV was letting by.
Reply to the thread, titled "automatic air release valve" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Thread starter
Joined
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
valve
apcdave,
apcdave,
