back boiler probs
View the thread, titled "back boiler probs" which is posted in Boiler Advice Forum on UK Plumbers Forums.
stevieboy33
My back boiler seams to fire up ok but when it starts burning after a minute or so just switches off,then starts the process again.Ive been told it could be a pump issue could anyone tell me if this is the case? any input would be grateful.Also if it is the pump were would it be located its not in the cylinder cupboard,and ive got laminate flooring all through the house? pls help
Hello Steve, the advice will probably be to call someone qualified to sort the problem.
However, is the hot water gravity fed or fully pumped? ( how many pipes come of the boiler?)
is the floor wooden? then the pump will probably be located under the floor near to the back boiler.
Reply to the thread, titled "back boiler probs" which is posted in Boiler Advice Forum on Plumbers Forums.
stevieboy33,
stevetheplumber,
