balanced flue for gas water heater.
View the thread, titled "balanced flue for gas water heater." which is posted in Gas Engineers Forum on UK Plumbers Forums.
I think there is a little stubbornness here
If a window is openable it is illegal
Regardless of how you open that window. If it opens it opens
If you remove hinges and handles ? Surely it's then a non openable window?? I wouldn't bother as disconnecting is easier. ( just being devils advocate)
I think simply screwing it shut doesn't render it non opening, same as removing handle. Grip fill, screws and a silicone type seal would make the window un openable. But then this could be a problem if kitchen didn't have a door to outside for ventilation?[/QUOTE
What about a window other than kitchen, Why cant we get a definite answer does anyone know ? usually someone on here rattling off the rules and quoting BS numbers answer please ! because screwing windows has been done for years.
But you are back to, it was fitted & been serviced by BG for the last 20 years, why now is it ID , customer is well P***d off, :furious3: engineer gets punch in face, :90: What are the written rules on screwing shut windows ???
There are non that I know of in 5440. The building regs may have something for ventilation in habitable rooms bit?
I would ID and leave. If custard won't let u ID call transco.
Punch in face = assault call police.
Openable I surmises that openable means readily openable with items close to hand or
Openable I suppose would have hinges
What pray would a sash window need doing to it to render it non opening? (Excludes 2000 coats of badly applied gloss)
Reply to the thread, titled "balanced flue for gas water heater." which is posted in Gas Engineers Forum on Plumbers Forums.
Chris21,
Ermintrude,
