Is it normal to check the POC on a fire with a balanced flue and decorative flame effect, with the flame effect tap switched on or off?
I wouldn't FGA an RS appliance unless the MI's stated so.
Correct it adds shed loads of secondary air it make the flames yellow, floppy and more realistic, hence the carbon (soot from the incomplete combustion) don't do it again or you may poison your O2 cell in you FGA, if not pulled out quick enoughIt will do its altering the way it burns to give it a real flame look
Reply to the thread, titled "Balanced flue gas fire" which is posted in Gas Engineers Forum on Plumbers Forums.
