R
redapple
Hi
I was wondering If I might be able to get some help in balancing my central heating system.
I recently switched on the heating and found some radiators are hotter than others. It is a new system and was flushed.
My plumber told me that I would need to balance it and gave me a general idea but to be honest after doing some reading I thought better ask.
I have a Worchester Bosch FS 30 CDI. I currently have it set to setting 4 65C. It is located on the Third Floor
3 floored house with a bottom floor extension
- first floor 7 radiators
- second floor 5 radiators
- third floor 2 radiators
Unvented cylinder tank fitted with AVB located on second floor.
The system is split up into 4 Zones
I have a digital thermometer 🙂
I have included a diagram hope it doesn't make it too confusing.
I am not too sure if I turn all the zones on and then measure which order they heat up or do each zone separately?
When adjusting the lock shield from being fully open to closing what temperatures on flow and return I should be looking for allow the boiler to operate efficiently? and should I turn the boiler to max temperature or keep it at setting 4 when balancing?
Thanks any help much appreciated 🙂
