Bar shower mixer valve help (DIY)
View the thread, titled "Bar shower mixer valve help (DIY)" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi!
Fitting a new shower and after some research I bought these fast fix brackets online (looked a lot more straight forward than the ones it came with. Crank something???) Anyway, after fitting it, the nuts don’t completely cover up the thread (photo attached). Is this normal? I was cautious about over tightening in case I cracked a tile or something. Although I’m not sure they can be tightened much more. Any ideas what I can do about this? Have I done something wrong? Is there anything I can buy to cover the gap?
Any advice will be appreciated.
Thank you very much!
If you really want to you can remove the valve and the shrouds then cut off the excess threads with a hacksaw.
You need to file the resulting face nice and flat as this is what the seal is made against.
I have done this for fussy customers in the past but most people don’t worry about it.
Reply to the thread, titled "Bar shower mixer valve help (DIY)" which is posted in DIY Plumbing Advice on Plumbers Forums.
Ozberry,
Ozberry,
