Barking Brassware Company
View the thread, titled "Barking Brassware Company" which is posted in UK Plumbers Forums on UK Plumbers Forums.
V
Veggie Dave
A customer has some BBC basin taps that she's desperate to keep, but they're dripping. The problem I have is that the rubber washer for these taps has a groove for the valve face to sit in and I can't find anyone who stocks these washers. I've reground the valve seat, which now seems to be perfect, and used every single washer I can find but I can't stop the tap from dripping.
It's now down from a constant drip to one drip every 50 seconds or so but that's really not good enough. Does anyone know where to find these washers?
Cheers.
You've spent a lot of time on this job Dave, I hope the customer appreciates it and will pay you for it all as well as for the new taps and fitting them.
Two lessons learned, I think:-
1) Sometimes it isn't possible to do what the customer wants.
2) Make certain a spare part is available before starting the preparation work to fit it.
I have asked at the two merchants I was at yesterday for you and had a look on-line. No joy I'm afraid.
All my customers are lovely. I'm not joking, either. 😉
Barking Brassware was taken over many years ago and renamed Barking Grohe.
I don't know which one of the Grohe brothers bought the company but the factory which was in River Road, Barking is long gone.
I have a load of discontinued oddities. Can you post a photo?
I take it the Barking type washers in the Holdtite tap washer box aren't the ones?
I can indeed.
Sadly not, no.
Best quality brass ware you could get.
They do appear to be very good quality taps, and they've been in the house for a long time, which is pretty old but renovated to a very high standard with as many original fittings and fixtures kept as possible, hence why the customer really wants to keep the taps if at all possible. It's a question of history not finances.
Are they not just worn into the seating?
I don't think so. I did another set of BBC taps at the same place and the washers looked to be in much better condition, with an intentional grove/channel in the face of the seal.
I have, however, sorted the tap out now but I still want to find the proper washers if they exist.
Might be a long shot but there is a shop in cheshunt ,Hertfordshire called house of taps ,he has been there for donkeys & has helped me out in the past with obsolete tap bodies ...you never know
The washers are supposed to be flat. Yours have just worn
The standard Holdtite tap washer box (from Toolstation) has 2 sizes of Barking washers in it
I've got the tap to stop dripping (modified a seal) but I never found the correct seal. At least not yet...
Hi Dave, I have the same problem with some BBC taps (both bath and sink).The plumber currently working at my bathroom renovation says that trying to fix the washers will damage the taps. Did you have the same experience? How did you fix the problem? I really want to keep them as they are great quality. Thanks
I believe it's got to do with having to unscrew the knobs. The green and red dots (cold and hot ) will get damaged in the process too apparently
I can't say as I am not a plumber and therefore I can't assume a job is easy without knowing the inside outs of it. That's why I sent a message to Dave. He has dealt with similar taps.
thats just a normal tap washer thats worn down on the seating your looking for something that doesnt exist you might find domed washers will stop it if you can find any
Thanks will try look for those.
Not sure why you say that I am looking for something that doesn't exist. Am I misreading your message maybe?
I used to love BBC taps to weight up my scrap box properly made taps not like the tut these days...regards turnpin:grin:
Reply to the thread, titled "Barking Brassware Company" which is posted in UK Plumbers Forums on Plumbers Forums.
Veggie Dave,
turnpin,
