R
Roboloid
Wow - first of all thanks all for your thoughts and suggestions - but no fighting please!
I should have said in my first post that I did put some unblocker stuff down the bath drain a few weeks ago, but clearly its not had a lasting effect (I used "Buster Bath Unblocker" - no discolouration of any of the chrome (I was very careful!)). So, based on your responses I probably shouldn't put anything else down there? Or if I do, stick to the same brand? There's no problem with the basin draining - although I have removed a faulty pop-up plug so it's just a gaping pipe at the moment - not very attractive and needs fixing.
Re: the point about the drain being removable, I'm not sure I entirely understand which bit you're referring to, but if its the chrome bit that's actually in the bath, then it looks like you can unscrew it to clean underneath - is that worth doing?
I think I might take some photos - not necessarily of the undraining bath, but of the marks on the lino and the water seepage from the toilet and see if I can get any action from the landlady. I have pointed it out before but not sure that the message got from letting agent to landlady/ Rentokill damp guy who came round ages ago.
Thanks again!
Roboloid
Thanks again!
Roboloid
