View the thread, titled "Bath not having hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
C
CrabbyZac
I just moved into a new house it didn't have any central heating only two gas fires. we had a plumber in to fit a central heating system with a combi boiler, the radiators are hot plus both sinks down stairs produce hot water however in my bathroom I cant get hot water for the bath. it has a short burst of hot water then goes luke warm, I have tried turning the water temperature on the boiler to high but still no affect does. we have a shower which is hot plus the sink in the bathroom is also running hot but the bath remains luke warm, anybody know what I can do to sort out the problem
Thank You
hi crabbyzac welcome to the forums. sounds like you need to turn the hot tap down, you are letting too much water flow through before the boiler has a chance to heat it. it will just take longer to run the bath but you will have a hotter bath.
Reply to the thread, titled "Bath not having hot water" which is posted in Bathroom Advice on Plumbers Forums.
