Tmv only on new. Replacing an existing doesn't need one. Do you have a shower or anything similar. Could be mains cold back feeding through cooling hot.
There is a separate mixer shower above the bath taps which seems to be fine.
I'm not at home to check the exact makes, I believe it's a Potterton, 1980's gas boiler and here's an image of the cylinder.
Check under bath and see if you have on of these.
Google Image Result for https://cdn.aws.toolstation.com/images/141020-UK/800/18520.jpg
If you don't have a TMV send a picture of bath taps and could you try get a clearer image of the cylinder and pipework later on, take a step back and include as much pipework as you can
Does anyone else see two pumps? Maybe a thermal store with a mixer on the side...
Thanks for all the advice and prompts. I’ve worked out there is a TMV on the cylinder pipework and think this might be the problem. I’ll let you know how I get on.
