buckley plumb
want to alter the flue on the above boiler as it terminates into next doors garden.it needs to be terminated verticaly- the problem being the boiler is 400mm from the flat roof ceiling inside - i need to fit 2 elbows to take it the required distance from next doors boundary this would take the second elbow to the ceiling height and the depth of the flat roof from the felt to the plaster is only 6" i would be cutting the vertical flue terminal down very short is there a min distance phoned baxi and they said they dont do a 4" vert flue for the old baxi only 5" and i would have to fit an adaptor and then the elbows . anyone come accross a problem like this . i could dropp the boiler down but that would mean a lot of work
ant
ant
