Baxi 105e instant problems
View the thread, titled "Baxi 105e instant problems" which is posted in UK Plumbers Forums on UK Plumbers Forums.
MK Heating
Went out to look at a 105e instant earlier, Im normaly ok on these, I rather like them.
However, this one whe I arrived had the fan light flashing, reset it and it fired up, fan was pulsating very erratically, and the flame was going up and down. I checked the voltage at the fan ad was getting between 25v and 730v???
while lit the burner sounded like it was spluttering.
After a while the fan did start to spin at a constant speed, but the burner didn't improve
When running DHW turning the hot water dial down didn't alter flame size or hot water temperature
I thought PCB. But the more I think about it, the more I change my mind
possibly fan relay in the pcb,however if its a HE version take a good look at the aps
Opened it up to look at the board and you could fry an egg on the big square relay, that normal? Don't ever recall noticing it before
I've had a similar problem on an Ariston Microgenus (horrible) - there's a plate which is riveted to the back of the burner box just above the heat exchanger, the rivets had snapped and he plate was blocking half the heat exchanger. The burner was all over the place!
Reply to the thread, titled "Baxi 105e instant problems" which is posted in UK Plumbers Forums on Plumbers Forums.
MK Heating,
bewsh,
