baxi boiler leak
View the thread, titled "baxi boiler leak" which is posted in Boiler Advice Forum on UK Plumbers Forums.
M
morgi27
hi guys new member here!! i have a small problem,with a my baxi boiler,it as a small leak of cold water,ive looked into the boiler and its leaking from the flow switch!! i already have a new spare replacement switch to hand but i wondered how hard is it too replace???? is it a case of just of removing it or do i have to drain boiler etc
many thanks for any replies
michael
What do YOU think will happen if you attempt to remove a water flow switch without isolating and draining the boiler first.
michael
:welcome: to the forum morgi27 ... I'm guessing a 105 or the like but what model baxi you got? ... By flow switch do you mean heating or hot water? And lastly how confident are you around water and electrics? Not wanting to scare you or anything 🙂 Some repairs a relatively good DIYer can get a way with ... How do you rate yourself?
Reply to the thread, titled "baxi boiler leak" which is posted in Boiler Advice Forum on Plumbers Forums.
morgi27,
diamondgas,
