E
eraser2002
Hello hope someome can offer advice with this boiler im pulling my hair out.
The symptoms are:
The hot water always works fine - the hot water light and burner light comes on and works etc
When i switch the heating on in morning using wall mounted thermostat, the boiler starts up (low whirring sound like the pump), and within say 30 secs the boiler sounds like its working and the burner light comes on but flicks straight off, and then sits for a few minutes then tries again... then eventually it will work and the heating will come on
Seems to have improved over week or so since i been using the heating but done this again this morning. When i first started using it took half hour or longer to get heating on... No errors come up etc = but it just doesnt work properly 🙁 the burner doesnt stay on.
Had 3 engineers from heat team 2 have swapped the same control board and still not working right.
Someone told me it could there could be a heat exchange switch problem (sticking) as it seems to be worse when the boilers been left for longer... i didnt have it on the night before at all as i was out...
Any help appreciated
Chris
The symptoms are:
Chris
