C
chillyisons
Hi, This boiler has been problomatic for years with numerous parts being fitted anually Ive lost count of the number of temperature sensors ch and dhw, diaphrams, 2 pressure releife valves, a stuck diverter valve plus a leaking pump but has now completly stoped working. The diverter valve has just been changed and the boiler fired up with excelent results the pre heat heated the water then stopped where as before it heated for a long period to get to the set temperature as it was heating the rads as well. A small leak was spotted at the back of the diverter valve so the boiler was drained and everything was nipped up a little tighter. Now I dont know if the pcb got wet the last time it was drained but the boiler now refuses to light. When switched on the fan spins the pump starts up and the electronic ignition clicks but almost straight away the fan stops and the following two lights flash
30oC - FLAME FAILURE
40oC - SAFETY THERMOSTAT ACTIVATED
There is 240v at the main block and the fuse at the main block in the boiler is fine. The air pressure switch clicks when the fan spins and a contunuity check shows the switch to be working. I have blown through the pressure pipes into the flue (Both the rubber pipes) and they are clear. I have blown through the rubber pipe to the brass fitting in the burner which is also cleare. when the fan and pump initialy spin the pcb shows 240v at its various sockets which is cut as soon at the fault lights come on. We do have a gas supply to the house as the cooker hobs are working. The boiler last drain down was Sunday and the pcb has been remover and checked for dryness since (there were some droplets under the pcb in the plastic control housing. Its now Tuesday and it still wont fire up with what must now be a moisture free pcb. Any ideas on what to test next? Thanks in advance
