View the thread, titled "baxi due tec lossing water" which is posted in Bathroom Advice on UK Plumbers Forums.
erj
hi as above baxi due tex needs toping up every other day, PRV not passinf nothing running down the con pipe, in a bunglow so all pipe are eather in the loft or in the wall nothing under ground, any one any thoughts l;ost for what to check next.
Is the auto air vent in boiler passing?
Slight leak on a lockshield valve?
Automatic air vents in attic leaking?
Because it needs topping up every other day , it sounds small and evaporating on hot pipe work. IMHO
Reply to the thread, titled "baxi due tec lossing water" which is posted in Bathroom Advice on Plumbers Forums.
