View the thread, titled "Baxi Duo tec 28 service" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Scott_D
Subscribed
Got one one these to service next week but I dont see many
Its 5 years old and still under warranty
Is it recommended to replace the burner door seal?
Anything else that should be replaced eg electrodes?
Done alot of work on these. Quite a nicely designed boiler. Especially the added touch of a condense drip tray at flue point to catch any water ingress...more Boilers should have this.
I'd recommend changing the seal when removing the chamber front.
Also I like to fit an Angled schraeder extension to make it easier to check/top up expansion vessel pressure for subsequent visits.
Good idea with the bent Schrader valve. I bought one recently from Halfords definitely makes it easier
Got 20 or more of these on my books and every 5 years it's a new seal very hard wearing , full strip each year and drop the pressure to check expansion vessel probably one of the best boilers to work on very reliable . Kop
Reply to the thread, titled "Baxi Duo tec 28 service" which is posted in UK Plumbers Forums on Electricians Forums.
