View the thread, titled "Baxi megaflow system he boiler showing c1 only fan running" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
lee engineer
Hiya i normally install but went to breakdown of baxi megaflow he system condensing boiler, 3 years old, when reset fan runs for 5 secs then stops and nothing happens. Not familliar with this boiler, no instructions on site, to late to call manufacturer. Boiler displaying c1, no power at pump. Is there a concealed reset? Does c1 simply mean its calling for heat? I think error codes start with e, is this right? Im thinking fan/pcb. If any one is familiar with this boiler please help thank you liam
c1???? not in the fault codes it should be e1 followed by a number 33 etc
Yeah just found that out when looking at MIs online, but boiler showing c1 as it should do, so not detecting there is a fault even though there is. Not familiar with repairing condensing boilers ill call baxi. Any help is much appreciated though thank you. Liam
have a word with baxi,there are no concealed resets you might have a pcb issue,come back if baxi dont help do you have the trade only number?
There is a pcb on the fan aswell as the main board. Ive had the same prob on W greenstar and it was the fan. Someone said to me the manufacturer engineers can plug in a computer to test for faults is this true or nonsence?
unlikely to be the fan you would get code E160 pm,ed you the number
They have a trade only number?? How many other manu's have a trade only number? Is there a list somewhere gas man?.....maybe we could put it as a sticky in the registered gas safe forum.
Sent from my Desire HD using Tapatalk
Reply to the thread, titled "Baxi megaflow system he boiler showing c1 only fan running" which is posted in Boiler Advice Forum on Plumbers Forums.
