Guest viewing limit reached
Belfast sink - joining old waste to new 40mm trap and pipe
View the thread, titled "Belfast sink - joining old waste to new 40mm trap and pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all
We're having an old belfast sink fitted in our WC/utility room. We'd like to use the existing old waste; and by all accounts it'd be a pig's jacksie to remove even if we wanted to!
The threaded section in the photo measures approx. 1.88" / 47.8mm outside diameter and 1.24" / 31.5mm internal diameter.
The only thing I can think to use is something like this:
But whilst the sink out will be inside the reducer, which is good from a gravity point of view, the 40mm trap and pipe will also be inside the reducer which ain't so great.
So I wondered if there are any other options? Anything entirely different? Or something along the lines of the rubber reducer, but with a threaded connection on the smaller end to it connects to the 40mm trap and pipe properly?
I'll keep looking in the meantime.
Thanks a million
For the benefit of anyone coming across this in the future who finds themselves in a similar situation, my plan (as outlined in post #25) worked a treat, and I'm set up and all works perfectly.
Thanks one and all for the great help. I wouldn't have got there without you!
Reply to the thread, titled "Belfast sink - joining old waste to new 40mm trap and pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
Plumb Line,
Plumb Line,
