No probs mateWill be tomorrow now I'm not going back 😀
It doesn't say on any Sentinel X800 bottles that I'm holding right now that it can be left in the system for a week. It says under application on the label on the rear, the following:It's on the bottle
To clean in accordance with BS7593 Sentinel X800 should be circulated with all valves open for 1 hour. After cleaning, the system should be drained and flushed through all drain points. If required, can be dosed up to 24 hours in advance....nothing mentioned anywhere about a week.
On the other point, allowing sludge, metal, rust and all the crap that X800 has dislodged to circulate in a 25 year old microbore system for a week will block manifolds, old valves, block dips in microbore pipework and make the system worse before it was flushed. Pointless.
It's not a week and after using it , the X800 was a great success. I completely flushed it out on the manufacturers recommendation after an hour. Not a trace of anything was left circulating.Doesn't say max how long so it's gone from 1 hour to 1 day 😀
It's going to do that anyway as your not flushing just one circuit/ rad
Reply to the thread, titled "Best chemical flush?" which is posted in UK Plumbers Forums on Plumbers Forums.
