Guest viewing is limited
Biasi riva advance HE
View the thread, titled "Biasi riva advance HE" which is posted in UK Plumbers Forums on UK Plumbers Forums.
MZR
Hi All
im at a loss with this boiler !!!
error code is 2 flashing green and solid red and solid red lock out. manual says lack of burner ignition,
ive changed the 2 electrodes right and left and the gas valve check power to the gas valve all fine , the boiler goes to fire pump runs fan runs and you hear it spark but no ignition just locks out , fiddled out with the wiring harness to the gas valve but pushing down on the 2 pins and it fired then switch tap off and back on locks out then fiddle about again stills locks out keep fiddling and pushing it fires !! now i got it to the point where i thought it was fixed few hours later same locks out ???? WTF ?
ive been on to biasi who are no help restored the gas valve to factory setting checked everything possible i can think of, the condensate does not have wires going to it.
Im thinking PCB but biasi said no chance ?
what you guys think ??
Reply to the thread, titled "Biasi riva advance HE" which is posted in UK Plumbers Forums on Plumbers Forums.
MZR,
