Biasi Riva Compact HE - Air Pressure Switch
View the thread, titled "Biasi Riva Compact HE - Air Pressure Switch" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
My Biasi boiler was cutting out, hence no hot water or heating and the fault code was saying faulty air pressure switch.
I replaced the switch and it worked all evening and then cut out again.
If I do a complete shutdown and re-start after a few hours the boiler works again but only for a few hours before same fault.
Fault is still showing faulty air pressure switch.
The fan is starting and running ok.
Any ideas would be much appreciated.
I am a qualified electrical engineer and have no intention of messing with anything gas related but this problem to me seems to be a electrical problem.
All I am trying to find out is if anyone as come across this problem before.
Here we go again , why is it always engineers.
What is you gas safe no , you have not got one . Forum rules , as said above , we will not give out advice on gas appliances
Reply to the thread, titled "Biasi Riva Compact HE - Air Pressure Switch" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Robert Whitlam,
ShaunCorbs,
