Biasi Riva HE. They built a boiler you cant service.
View the thread, titled "Biasi Riva HE. They built a boiler you cant service." which is posted in Boiler Advice Forum on UK Plumbers Forums.
A
Armitage Shanks
I diagnosed the problem in 2 mins, magnetic proximity switch not energised for DHW. Ok, lets clean the flow switch. Errrrrrrrrrrr, none of my 65 spanners or sockets fit the top nut, to big for 17mm, too small for 18mm. Out of curiosity I call tech, they say" oh ye, its a problem, throw the whole hydralic block away and fit a new one". The DHW gauze filter is in there and should be cleaned as part of a service.
I did actually manage to remove the plunger assembly in the end after much cussing and removing other components to give more space for a pair of stilsons. Whilst I had the part out I also filed the brass nut to fit a 17mm ring spanner, so in future it will be easy to service the filter and plunger.
Well done Biasi, I wont be recomending any of your products any time soon.
Any other engineers had the misfortune to come across this one?
No, and like I said, biasi tech confirmed NO SPANNER WILL FIT. Obviously , being european, all other nuts on the boiler are metric.Ive not seen this in 40 years of playing with boilers!
The least they could have done was sell you a 'special tool' that fit's it! Binning parts for fun, what a joke
Depends on how many Biasi boilers you may work on! Can pick a set of cheap spanners up for a couple of quid, saves stripping a boiler to get a nut off
The trouble is, the nut is about 17mm across flats, the thread is about 30mm dia, and a thread that size , left for a few years aint gonna shift with the torque you can apply through a 17mm nut made of brass, thats why it has to be a stilson butchery job. Its a **** design, cant beleive no one else has seen this prob?
For every problem there is a solution
Mine usually involves a 18v makita grinder and a cutting disk
the modern version of a axe...........i got go and get help for this pent up anger against ideals and boilers that are cheap tat:dizzy2:
Hi here a socket that probably will help you:HAZET 880AMGT-3 11/16 (17.5 mm) socket it is used for replacing spark plugs on some BMW MODELS but as you can see it is an AF11/16 largely used in the past.
I think the Biasi technical advisor was talking just because he had the tongue.
I tried all AF sizes, whitworth etc. None fit. But your all missing the point. Biasi tech told me " even if a spanner fitted ,it wont undo it because the thread is too large for the torque you can apply through the small brass nut,it just shears ". The nut is part of the casting.
When you see it youll know what I mean.
Wait till you try and change a pcb on one! its unbelievable how bad it is to do, thank god for thier technical line.
Reply to the thread, titled "Biasi Riva HE. They built a boiler you cant service." which is posted in Boiler Advice Forum on Plumbers Forums.
Armitage Shanks,
southcoastboile,
