Bleeding Grundfos Selectric pump
View the thread, titled "Bleeding Grundfos Selectric pump" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
Robomonkey
Hi all
Can anyone help with the above?
when the pump first starts I can hear a little gurgle, and when it stops I can hear a small slosh as water settles, when it's running it sounds fine.
Until recently I didn't know you can bleed pumps, so read a little about it and figured out you just need to remove the large screw/cap in the middle. So I've done this, removed it completely, but nothing happened, no water or air!!
What else do I have to do?
Im happy to stop melding when I understand what's hPpening, and that he pump isn't going to overheat or damage itself becuase it's trying to pump air.
Could either of you give me a little explanation as to whats happening, and why when I remove the bleed screw nothing happens.
Reply to the thread, titled "Bleeding Grundfos Selectric pump" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Robomonkey,
Howsie,
