Blending unvented hot water
View the thread, titled "Blending unvented hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
Scott_D
Subscribed
Can you blend the water as it leaves the cylinder or does it have to be done at point of use?
just thinking I could use a slightly smaller cylinder for a tight spot as the stored hot water would ‘last longer’ You don’t need 60degree water to wash your hands or the dishes.
Should be point of use Scott , there is a measurement allowed after the cylinder to the tap but sorry cant remember it .
However loads put them on the top of the cylinder .
Reply to the thread, titled "Blending unvented hot water" which is posted in Bathroom Advice on Plumbers Forums.
Scott_D,
townfanjon,
