View the thread, titled "Blocked Tap Filter" which is posted in UK Plumbers Forums on UK Plumbers Forums.
solavie
I have fitted a new tap. However after a week the plastic filter has been clogged by debris in the system and there is only a reduced flow. How do I take these plastic filter off the bath taps. Bought them from B&Q
Do you mean the plastic bit in the end of the spout ? If so it will screw out, you may need a pair of grips to do it.
about a year ago, had the same problem for a client, as nick says they generally shouls screw out. for some obscure reason, this one had been glued in.
i ended up buying the lady a set of taps!!!
it was also bought from b+q.
hopefully now updated a pair of grips on it, and it should unscrew.
tip. replace it with a chrome aerator type, looks like theres a lot nore water flowing in than there actually is.
shaun
Reply to the thread, titled "Blocked Tap Filter" which is posted in UK Plumbers Forums on Plumbers Forums.
