Boiler and cylinder replacement
View the thread, titled "Boiler and cylinder replacement" which is posted in Boiler Advice Forum on UK Plumbers Forums.
king of pipes
Subscribed
Had a look at this job it needs upgrading boiler and cylinder the house is quite big 17 rads, big rooms open vented at present , some pipework under concrete floors client wants unvented and little as possible on show conserned about pipes under the floor so looking for ideas chaps I've a few in mind boiler without a pressure sensor so system can be run at a low pressure but still sealed ? . Kop
Yeah but as I said client don't want to see it Simon , I can do it with a Intergas boiler possibly a Worcester I've done it before with the old CDI Classic not sure about the newer range ??
Went with a Intergas Hre 40 kw system boiler coupled with a OSO delta 300 litre unvented cylinder 3 zone heating and hot water , upgrade on living room rads and all valves. 😉👍
This one is taking shape now bit of a change from bathrooms 😃. Have a relaxing weekend chaps . Kop
Reply to the thread, titled "Boiler and cylinder replacement" which is posted in Boiler Advice Forum on Plumbers Forums.
king of pipes,
king of pipes,
