V
vern
What did ideal say today Tom?Expensive!
Still have reservations about the boiler, HW not fantastic - I'm convinced the plate hex isn't big enough. Am revisiting the boiler on Friday and will report back then.
Bloody hell Tom hassle or what? Bet you wished you had fit a logic 35 now or 831 .....ideal need to nail this and fast!Engineer came and fitted new PCB with "altered HW parameters" which even he didnt understand, and throttled CW down into boiler.
Need to see how it's performing on Friday, as before it was running off pre-heat water then taking another minute to get HW to taps. Engineer said he thought boiler was struggling to keep up due to a slow/low fire.
I'm going to fit a combi save valve as the customer thinks its a good idea anyway, aye this will help the HW runoff.
Ideal rep is keen to help, and is determined for the customer to be happy, but I'm not sure how they would go about it. She asked for my opinion and I told her I didn't think the plate hex is big enough if it can't retain water long enough to heat it sufficiently. I'm sure a logic 35 would be better in the same situation, even though on paper, the specs are very similar.
Hi Tom
Very good service, as you say, but they aren't going to be doing that for everyone!
Am I understanding you correctly that Ideal say the boiler is acting as designed, and just has a very poor DHW flow rate for its kw rating?
Yes you would be correct. They must be in agreement that something isn't right or they wouldn't be addressing the problem in such a way.
By contrast I fitted a 30kw logic on Monday and under similar circumstances the HW was fantastic. It seems the vogue doesn't want to produce any more than a 35 degree rise in the water temp, whereas most other boilers can easily exceed this in the real world.
Interesting, I take it the boiler takes a input to regulate Hw temp from both a thermistor and also flow sensor like the logic, can you hear the burner rate increase as you increase water flow?
Can't really hear anything roger, boiler is too quiet! Lol.
It uses a turbine to measure flow, but funny thing is, when I was getting 15l/m at full rate through boiler, display was only registering 12.
Reply to the thread, titled "Boiler choices." which is posted in Boiler Advice Forum on Plumbers Forums.
