buckers
This is my first post so please be gentle. Moved into my house 4 years ago and had boiler serviced/ fixed as had no heat. They replaced pump, flushed system and serviced the boiler. Its never actually been a working system in my eyes. Main issue is when on timed heat and water the boiler will fire correctly at the exact time but after say 20 mins will shut down. The home is still freezing. It will eventually fire back up could be in 5 mins or 45 mins later. I have to switch the power to the timer off and wait a few mins for it to re-fire. This can happen 7-8 times each day. Was also told as my boiler is old the timer needs both water and heating on to allow "heating only" to work. In the summer i can just use water but in the winter i need to use both or else the heting wont come on. I have half rectified the rads taking 2 hours to heat up downstairs by balancing the systen as per another thread so hope in a few days to equal the heating across the system. My details are below if anyone can help as this has been going on for ages.
Boiler Myson Orion Fanfare 60 si ( approx 20 years old)
Timer wired to boiler is Drayton Lifestyle LP241
Old Sunvic room stat in the ground hallway
Pump on cylinder is Grungfos UPS 15-50
P.s
A sparkie mate has checked the stat and said it is kicking in, but the cover was loose but 12 months ago and i put a meter across 2 live wires by mistake and got a little kick. Think this is when my on/off issue started. Have I blown something in the timer?
Many thanks for looking
Ian
P.s
Ian
