View the thread, titled "Boiler Control BoX repair needed" which is posted in Boiler Advice Forum on UK Plumbers Forums.
C
ceedy
Just had the New Gas valve fitted to our old Housewarmer.
along with the repaired myson/Thorn/Baxi Control Box.
This box has been repaired twice by the same company with the same result.
it will run for 30mins or so , then stop/switch off/pack up ? and never go again.
It a very simple single sided PCB with only a few odd resisitors/ caps/ transistors etc. and a couple of relays.
The present repairers just seem to want to repalce a single duff transistor but never look for the root cause of the failing item .
If I had Circuit diag I'd do it myself ..
So looking for a reliable company who will do the job properly !
here s hoping.
C.
time to purchase a new box off the net?
Yup.. reckon so ...very limited supply .. Just reluctant to spend over 100 pounds again on a Boiler thats being replaced Very soon 😡.
mind you could go to local partsarena stockist and get rogered to the tune of 274 +vat !! 😀
Reply to the thread, titled "Boiler Control BoX repair needed" which is posted in Boiler Advice Forum on Plumbers Forums.
