G
greenhorn
I have a Potterton Netaheat 50 which heats 5 rads downstairs and 4 upstairs (incuding a bypass rad in the bathroom). It is an open vented, fully pumped system fitted with a combined feed and vent.
During the summer, many of the rads were removed for redecorating and the valves fully opened on each end. When the heating was needed a month or so back, I noticed that only the downstairs rads were working.
I had the boiler serviced and the engineer said that the upstairs was not working due to a blockage in the system which needed power-flushing. I did not book him in but consulted Google.
I found several forums where people had similar probs to mine and one excellent answer which advised them not to proceed with a power-flush until they had ensured the system was “balanced” – especially if rads had been removed for decorating!
I tested the system by shutting off the downstairs rads and surprise, surprise, the upstairs ones all worked! - proving that the engineer was a liar (despite being Corgi registered - or so he claimed!) out to fleece me for a few hundred quid (he had also said that if the power-flush did not solve the problem, then he would need to replace the pump as well).
Unfortunately, I cannot balance the system as recommended (I have no radiator thermostats to start with) and the boiler only seems to work for 3 minutes before cutting off for about 10.
I stated by shutting down all the rads and only having the downstairs ones open a quarter of a turn, but the boiler only runs for a few minutes before shutting down for about 10 – and this was taking all day. I assumed that this was because no water was getting through to the rads. I then tried doing things in reverse by starting with all the rads fully open and then seeing how much I can close them without losing too much heat. I decided I should try shutting down the bypass rad (as that seems to be the only one getting hot), but that shuts down the system and I have to press the reset button under the boiler.
Even with all of the rad valves fully open the boiler only runs for about 3 mins before shutting down for 10 and I seem to be getting nowhere. It is a freezing cold day (temp should get up to about 4 degrees outside). My room stat reads 9 degrees and is calling for heat.
CAN ANYBODY HELP ME PLEASE?
