G
Gixxerman
Just had a system boiler installed by a local small business. I went with him as he has been doing it for years and is "time served".
The install went without a hitch until they came to switch it on.
Problem 1:
It wouldn't work on heating but would on hot water. The sparky checked his wiring many times and still no joy. Their conclusion, the pump is not working correctly. They put on a nearly new pump (to keep costs down). This didn't fix the problem. Then they concur that 3-way valve is broken. And looking at it, it looked broken as the manual override lever was pushed into the unit. They took it apart and found that the gearbox was broken off inside. Now I know that the valve is less than a year old as I had it changed, and it worked with the old boiler. Could they have accidentally damaaged it when they were fitting stuff (magnaclean etc.) in the airing cupboard?
Problem 2:
They removed some of the old electrical connections as it needed new supplies and a maintained supply for the pump run-overrun circuit. But the just left the old wires in the wall in plastic trunking and just plonked the boiler over it. Now I have a lot of loose plaster and exposed plastic trunking which I can't get to as the boiler is covering it. I would have expected them to have prepared the wall first before hanging the boiler. The hole for the flue is not flush with the flue (the hole is slightly too big) and they didn't plaster round the flue either. Is this normal?
Problem 1:
Problem 2:
