View the thread, titled "Boiler Heat Exchanger busted" which is posted in Boiler Advice Forum on UK Plumbers Forums.
get worcester to supply you with a nex hex then get a local gas guy or worcester to fit as your in london rates can differ alot
Was about to say that. But looking at the picture that isn’t a bad deal from Worcester. Especially if they said they would change the pump also.
Yeah that wilo yonos pico pump was fine he said
Thing i didn't understand is when i turned it to vent mode (set in the middle) i had no idea where it was venting air from..... there's no escape valve...
That’s a problem that goes back way further than recent work you’ve had done. Get Worcester to repair the boiler, get someone to powerflush the system and investigate why the problem occurred in the first place. I can’t see in the airing cupboard pic but is there a bypass and is it open? Also it might be that air is getting into the system.
Yeah I called them up and they registered it for me 😀
This is what's messed up with this trade at the moment. A boiler in stalled by a bg engineer but not by so a cash install that wont be registered with building control not registered with Worcester phone them up 5 years later and they register it.
No other trade would have that but ours just gets screwed over.
Also guy who installed it wasn’t gas safe as they arnt qualified out of hours / do jobs on there own time but many do
That's what I mean.
Worcester should turn around and say hahaha tough boobies (I'm guessing the other words I'd use would be blocked 🙂) you should of got it done properly now pay to get it repaired or replaced.
Fit a lot of these boilers at work. Have had terrible trouble with some of them airlocking.
They do exactly what you have described. My money would be on that.
Millsy 82 I guess you haven't got an actual say on the situation (i.e. what one would do) rather than the initial installation that I had no control over 😵
Hmm KingDoey it's kinda funny because I did think it was an airlock but that PP was convinced it's sludge. I find it interesting how if it is an airlock, bleeding rads doesn't solve the issue...
Reply to the thread, titled "Boiler Heat Exchanger busted" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Thread Tags
Suzan,
ShaunCorbs,
