In the unvented hot water panel you see the stickers on it so doubt it’s been knocked so that’s no the issue
But you have a tmv3 on your hot water out for some reason eg follow the top pipe out of the cylinder you will see 2 other pipes link to that with a chrome valve
Do you know why that’s on it ?
I have absolutely no idea, it's been like that since I moved in 2009.
In that case I don't have a cistern as this is the only item related to my boiler (aside from the boiler itself)
Yes, apologies, I should have said, you won’t have a cistern with an unvented cylinder.
No problem at all! Is there a valve that could be stuck or anything in particular I should check for the lack of pressure?
I don’t hold my G3 quali’s, but assuming the cold main is still ok, maybe the pressure reducing valve, or blending valve - but these would need a G3 registered engineer.
Personally I would remove the tmv valve and go back to how it was originally, would be a simple alteration.
