View the thread, titled "Boiler in kitchen cupboard" which is posted in Boiler Advice Forum on UK Plumbers Forums.
plumber0808
What open vent boilers are you lads/ladies fitting in kitchen wall units?
I have fitted a few intergas O/V in them but want to consider other options to put in a quote.
i just looked at the worcester RI, the depth looks a bit border line;
unit depth= 280mm ish
RI = 270mm* to have 20mm front clearance from a openable door.
Ideal logic plus heat only. It's a nice bit of kit. Easily fits in cupboard , can have a rear exit flue, but you need to order it with boiler as not std . Also need to direct wire to pump.
never understud worcesters ventilation chart for the RI they seem to make simple things complicated
Glow-worm flexicom has a direct rear flue and is only 600mm in height, think the ideal is 700mm?
Also fitted worc ri with no probs in kitchen cupboards
Reply to the thread, titled "Boiler in kitchen cupboard" which is posted in Boiler Advice Forum on Plumbers Forums.
