View the thread, titled "Boiler keeps cutting out - flame lift" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi
We have an ARISTON boiler (about 4 years old I guess).
The last few weeks it keeps cutting out randomly and stops producing hot water. The screen displays 'error 504' which according to the manual means 'flame lift'.
Does anyone know what this means and will it be expensive to fix?
If I press reset the boiler restarts and continues working but then randomly cuts out after a while.
mo7, Check your condensate pipe, would be my first sugestion. It may have a blockage in it ... you could also check the flue outlet to make sure it isn't obstructed at all. Flame lift sounds like flueing issues. It may just need a good service!! 🙂
I have no idea what any of that means - so will have to call in a pro.
Does it osund liek a problem that wil ltake a long time to diagnose/fix?
you should pay a fixed price diagnostic charge and then labour and part for materials would expect it to be at least £100 if its a simple fix
Just ask for someone to come along and service your boiler; explain the concerns and take it from there .... some good folk on here worht considdering .... post your local area and you may strike lucky 🙂
High burner pressure, cracked/distorted burner. As above, get a service and the problem should be spotted and fixed.
Reply to the thread, titled "Boiler keeps cutting out - flame lift" which is posted in Boiler Advice Forum on Plumbers Forums.
