Y
YoungMarkC
Hi all,
Please can you help me. I have moved into a house and so far just qualified for wet plumbing NVQ.
I have a Glowworm Compact combi Boiler. It is quite old I reckon as it still has a manual ignition for when it goes out.
I changed the Valves on the rad system and added an anti-lime scale solution as there was no scalemaster fitted. Probably should have put one on in truth.
I put Danfoss TRV's on 4 rads out of a 6 rad system. Left kitchen and Bathroom with normal lock shields.
Then once the heating was being used it kept cutting out and the boiler would keep working but the pilot and burner were out. You could still hear the pump running and circulating the water.
The boiler becomes so hot to touch on the front.
My mate is a Gas Safe engineer and changed the thermocouple but that didn't make any difference. He is unsure what it is and no-one else seems to know either.
It only happened after I changed the TRVs but surely they are not connected to the problem although it does seem strange it happened straight after.
I can also hear that the Rads appear to start getting hot when the hot water is being used. The reason for that is that you can hear the pipes expanding.
The TRV's are reverse flow although normally I think it doesn't matter what side you put them on but with these ones you need to specify which way the flow is an flick a switch.
Does anyone know what the issue is because I haven’t' the foggiest and nor does he.
Any help would be appreciated.
Best wishes,
Mark
Best wishes,
Mark
