View the thread, titled "Boiler kettling / cutting out." which is posted in Boiler Advice Forum on UK Plumbers Forums.
N
Natill
Hi, I have a problem with my Ideal mini C28 boiler. When running the hot water the boiler kettles, cuts out and restarts. I have cover so called an engineer out, he was struggling to diagnose so went and rang a colleague, he came back and said it must be the PCB circuit board or temperature valve, I asked if it could be the heat exchanger (he tested and said it couldn't be that.). The engineer came back and fitted the 2 parts, unfortunately it was still the same and then decided it was a blocked heater exchange. Which are not covered (blockages aren't covered), and to get a private engineer to sort. Yesterday I tried the boiler again, I Turner the temperature down on the boiler to minimum and it worked without it kettling, I turned the temperature up and it went to just over halfway on the temperature gauge before it kettled. I have turned the temp down to about halfway and is presently working (water temp about acceptable), is this likely to be the heat exchange or could it be something else? I don't think I have a lot of sludge in the system. There are no cold spots in the radiators. Thanks in advance Neil.
As per your last thread that was closed. No boiler repair advice is given on this forum.
Please don't continue to ask because you will receive the same response.
Reply to the thread, titled "Boiler kettling / cutting out." which is posted in Boiler Advice Forum on Plumbers Forums.
