Boiler Lock out.
View the thread, titled "Boiler Lock out." which is posted in Boiler Advice Forum on UK Plumbers Forums.
A
Asare Thagu
Hi guys, After turning the hot water tap off the fan keeps running for approx 2-3 mins and boiler goes lock out. To get the hot water I have to re-set the boiler every time. Any idea whats causing this problem?
Asare, 🙂
Boilers generally lock out for safety! If the burner is staying on as well as the fan after turning the tap off then you have a problem that needs pretty urgent attention IMO 🙂
As mentioned, you need some one qualified to check it out!
Asare, 🙂
I agree its for safety, but the problem here is soon I turn off the tap the burner goes off only fan runs for few mins and boiler lock out light comes up. To get the hot water I have to re-set the boiler again and again and ............
Without observing the sequence of events and comparing it with expected parameters I'd just be guessing Asare ..... Having to re-set can be caused by quite a few possibilities from flow issues to over-heating to flame and or flueing issues! Best advice has been given already IMHO 🙂
Reply to the thread, titled "Boiler Lock out." which is posted in Boiler Advice Forum on Plumbers Forums.
Asare Thagu,
diamondgas,
