Boiler not cutting out
View the thread, titled "Boiler not cutting out" which is posted in Boiler Advice Forum on UK Plumbers Forums.
J
jmcclintock77
my dad contacted me to say his boiler is constantly burning and his central heating pump is running even when the heating and hot water are off. The only way he can turn it off is via the isolation switch cutting the power to the boiler. Everything else seems to be working fine. If he flicks the heating on the rads get warm, and he also has hot water from the tank. (it's an unvented system)
Any suggestions - EON can't get out to him until February!!!!
Any help would be much appreciated
Cheers
James
Call a local heating engineer to have a look, If heating system is running uncontrolled then this could be a real problem as the cylinder is un-vented. Please get it looked at, asap. (don't wait on EON).
why not make a new post 'plumber required' stating where your job is and members will contact you directly.
similarly, if any member wishes to act on their own and give advice, please use private messaging with the o.p as the forum cannot be held responsible for incorrect/liable advice.
Reply to the thread, titled "Boiler not cutting out" which is posted in Boiler Advice Forum on Plumbers Forums.
jmcclintock77,
REDSAW,
