But, if you do not feel confident enough then I would suggest get a professional electrician out.
You don't need to cut link 6. The pump live is wired direct to the boiler as the PCB in the boiler controls the overrun on that boiler.
It will be a control issue. You just need someone to spend a little time going over the wiring to check the controls.
How does the Honeywell JB link 6 affect how the overrun work
So does that mean that if you have a Honeywell Junction Box you cannot use it to connect the pump to the boiler.
Does that apply to using any junction box or does the pump have to be wired directly to the boiler
Reply to the thread, titled "Boiler not firing up sometimes" which is posted in Boiler Advice Forum on Plumbers Forums.
