Billy Bob Bob
starting a new thread on boiler part numbers please keep this thread tidy i want common gas boiler part numbers i will kick this off with the duotec
BAXI DUOTEC HEA(note also fits gold,platinum,heatmax,promax,titanium combis)but not ga version,check if you have a HEA later version or HE earlier version
Short Parts List
Key G.C. Description Manufacturers
No. No. Part No.
311 Fan 5121447
426 Motor 3 way Valve 5132452
315 Igniter Electrode 720222801
316 Sensing Electrode 720222901
422 Gas Valve 5119647
Gas Valve (40 only) 5122286
624 Hall Effect Sensor 5114767
306 Burner (24/28) 5122149
Burner (33) 5114697
Burner (40) 5114698
419 Water Pressure Switch 5114748
400 Plate Heat Exchanger 5114708
415 Pump 248042
302 Flue Thermostat 5114747
421 NTC Sensor 5114725
420 Overheat Thermostat 5114729
504 Pressure Gauge 248090
503 PCB 24 5121862
PCB 28 720043401
PCB 33 720795201
PCB 40 5122287
baxi duotec 1(early version)
[TABLE="width: 100%"]
[TR]
[TD]Description[/TD]
[TD]Manufacturers Part No.[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f311"]311[/DLMURL][/TD]
[TD]Fan[/TD]
[TD]5114684[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f426"]426[/DLMURL][/TD]
[TD]Motor 3way Valve[/TD]
[TD]248733[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f315"]315[/DLMURL][/TD]
[TD]Igniter Electrode[/TD]
[TD]5114702[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f316"]316[/DLMURL][/TD]
[TD]Sensing Electrode[/TD]
[TD]5114703[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f422"]422[/DLMURL][/TD]
[TD]Gas Valve[/TD]
[TD]5114734[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f624"]624[/DLMURL][/TD]
[TD]Hall Effect Sensor[/TD]
[TD]5114767[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f306"]306[/DLMURL][/TD]
[TD]Burner (24/28)[/TD]
[TD]5114697[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Burner (33)[/TD]
[TD]5114698[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f419"]419[/DLMURL][/TD]
[TD]Water Pressure Switch[/TD]
[TD]5114748[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f400"]400[/DLMURL][/TD]
[TD]Plate Heat Exchanger[/TD]
[TD]5114708[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f415"]415[/DLMURL][/TD]
[TD]Pump[/TD]
[TD]248042[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f302"]302[/DLMURL][/TD]
[TD]Flue Thermostat[/TD]
[TD]5114747[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f421"]421[/DLMURL][/TD]
[TD]NTC Sensor[/TD]
[TD]5114725[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f420"]420[/DLMURL][/TD]
[TD]Overheat Thermostat[/TD]
[TD]5114729[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f504"]504[/DLMURL][/TD]
[TD]Pressure Gauge[/TD]
[TD]248090[/TD]
[/TR]
[TR]
[TD][DLMURL="http://www.partsarena.com/baxi/System/DATA/Dx/DS1/installation/3328/I49-3328/I49-3328.htm#f503"]503[/DLMURL][/TD]
[TD]PCB 24[/TD]
[TD]5118297[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]PCB 28[/TD]
[TD]5118642[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]PCB 33[/TD]
[TD]5118299[/TD]
[/TR]
[/TABLE]
Will post a load more when I'm home.
But one for now....
87161064330- Worcester Greenstar flow sensor adaptor. Common failure and seemingly difficult part to order correctly first time!
