View the thread, titled "boiler Pilot light keeps going out" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I dribble - esp when I am half asleep dreaming about 3/4 inch male iron to female fittings screw threads
..centralheatking QUOTE=croppie;524212]We're not that kind of forum.
We're the nice, shiny teethed ones who love most of our custards.
Some of us don't even dribble![/QUOTE]
sounds like a circulaton issue with the boiler, especially if the 3 way valve dont work proper. I would take the advise given by others and get somebody else in.
I don't normally comment on prices charged as not having been face to face with a job it can be very difficult to judge, BUT £450 to change a 3 port valve. Holey moley.
Did he wear a mask, was called Dick and arrived on Black Bess?
This must be one of those Millionaire plumbers we here about £450 to replace a 3 port valve, Please note the valve is only a gold colour not made of gold !
And the fact that it might not need one! Not sure of the boiler specifics, but it sounds like the boilers cutting out on over heat caused by poor circulation. Air in other words.
Hi oldieone - as you will read below a considerable number of us have commented on you post
one of the best ways to help us in the future is to feed back - did you get a solution with our help ?
or what have you done since ? centralheatkingQUOTE=oldieone;524153]I've just had my hot water tank which is driven by an old Ideal RE80N boiler in a Y system replaced by a plumber. I now have a problem that when I run the boiler after about 3 mins running with the rads getting hot the boiler closes down and even the pilot light goes out because the button you hold down to start it clicks up.
Any ideas?
Oldieone[/QUOTE]
Thank you everyone you are all very kind giving your time to advise.
This all started because the system upstairs had a leak and I had to get someone in to fix it. He changed the hot water tank as it had a leak in the inner coil. I didn't run it then but he said that it looked like I needed a 3 port valve therefore another quote. I couldn't proceed because the damage caused by the leak to the ceilings had to be repaired and because the ceilings were 1980 they had asbestos so had to be ripped out. They are back today for 2 days to finish the ceilings ans wallpaper (they are really nice people) and then I should be able to address the central heating.
However I did try to see what happened when I put the central heating on for a test and the F&E tank (I hope that's right) filled up with black water which went out of the overflow. The Boiler an Ideal RE80 (very old like me) ran for about 3 mins then tripped out (the grey button popped up) and the pilot light went out. I tried bleeding all the radiators but they seem ok as water comes out.
Where the man changed the tank it looks a nice job so I can't blame him. I expect at 73 there's no fool like an old fool. Maybe I should drain and refill the system then if that doesn't work find a plumber on here it's just I worry on the cost as the insurance had a £700 excess and the tank £750 and that would be £450 for the 3 port valve and I hear now I might need a new boiler at £3500 and on a pension I will soon run out. Sorry.
You are getting some good quotes ! £450. for a 3 port valve, £3500 for a boiler change, and you have just replaced the cylinder, what people are you dealing with ?? What area are you in I'm sure that one of the engineers on here would only be to happy to have a chat with you & point out your best options.
Swindon
Their are schemes in place to help people over a certain age with new boilers, get in touch with your local council or Age Concern I'm sure they will be able to advise you of your entitlements .
I believe that the customer has to be on pension credit or receiving benefits to qualify.
As you suggest, Age Concern should know.
Just to let you all know got a plumbrt in 3 port switch fitted wrong way round. He corrected it all now ok (I hope). Thank you all for helping me.
Reply to the thread, titled "boiler Pilot light keeps going out" which is posted in Boiler Advice Forum on Plumbers Forums.
