View the thread, titled "boiler selection" which is posted in Boiler Advice Forum on UK Plumbers Forums.
prs999
I am looking at a bit of advice about boiler size selection.
We are hopefully going to buy a house we have put an offer in on but it needs a new boiler if not a few bits more as well, I would like to have some input in the process as I have futher plans for the house in the future which I would like to prep for.
I have been looking at boiler sizes on the Worcester Bosch site (we currently have one which I am happy with, I will research other options later though) and the house is boarderline between a couple of options (all are combi)
at the moment it is a good sized 3 bed which I will install 2 zones in, one up and one down, but in the future I may add a 3rd zone in for underfloor heating in a new extention.
my main questions so far are
If I get a larger boiler than I need to futureproof myself, will it cost more to run on my current setup or will it just use more gas for less time?
also is there anything special I am looking for in a boiler if I want to add underfloor heating later? I know I will need a lot more bits when the time comes, I just want to make sure the boiler is up to it
also any advice about boiler selection generally would be great, are the ones with internal water tanks any good/worth the extra
cheers
Do you have any idea what system you currently have ?
i always like heat only or system boilers myself .
combis are ok for smaller properties although you can get ones that can easily cope with multiple hot water draw offs problem with them is when they go wrong can lose both hot water and heating
you normally lose hw and heating when any boiler goes wrong lol. however as stated above, if your going to stay a while go for a system and cyl, then youll have the ability to heat water via an immersion when the boiler fails. Also a cyl can allow solar hw as well if you plan ahead. get in a decent plumbedr to do the calcs and take it fm there, and look away fm wb try intergas for a decent boiler and if you must have a combi the intergas ones have less bits to breakdown🙂
Hi, thanks for your responses.
The system is currently a vented system but it is quite a mess and the boiler is currently in the bedroom so this will move.
I understand the issues with combo boilers buy i have had them in a number of houses but fore the following reasons i think fore me the pros outweigh the cons
You never run out of hot water
I work all sorts of hours so i don't have to think about seeing a timer.
In the house there is only the bathroom and kitchen sink which will draw hot water so a combi should be fine
Also sure to velux windows on the loft solar probably won't ever be an option, that said Bosch advertise a solar friendly combi
Cheers
Reply to the thread, titled "boiler selection" which is posted in Boiler Advice Forum on Plumbers Forums.
