J
Jockster
[h=2]Ideal Standard SE18 starting problem[/h]
I have an Ideal Standard SE18 boiler. For the past 3 years or so I've been having problems with the boiler starting. 50% of the time it is OK but for another 50% the boiler will not start up. I can hear the ignitor sparking(although cant see the spark) and I do think that a little bit of gas is getting through as I can smell it but it won't fire up.
I have tried all sorts to get it going such as resetting the timers, switching the whole system off then starting again and I have had a plumber out who has changed the motherboard(PCB?) and I think also changed the Gas release valve and possibly the solenoid. All this has not solved the problem.
I can get it going eventually when the cover is off but obviously this is not the solution(I don't really do anything its just seems to start better). It's been working fine over the summer although I've only had the water on. Now that it has got slightly colder I've now had the heating on and it seems the problem has come back. The thing is I have tried starting it with just the heating on and the problem is intermittant but its also the same with just having the water on too.
I hope someone knows what the problem is as I don't want to pay for Ideal to send out an engineer as the starting rate is £250 for a problem they probably know about. I did ring Ideal asking if they had a known problem but they couldn't even say yes or no as I wasn't Gas Safe registered.
Any help will be greatly appreciated.
Cheers
Paul
Cheers
Paul
