Boiler swap
View the thread, titled "Boiler swap" which is posted in Boiler Advice Forum on UK Plumbers Forums.
B
Britlee
I may sound a bit thick here but i have been a site plumber for 11 year and have never priced up for a boiler swap before. What i'm asking is what information is needed to work out which combi is sorted for a property.
Thanks Lee
Mainly dhw output
How many bathrooms
Also location paying attention to gas runs
Fluing
Also suitability of combi
If they have a combi just do a like for like on kw providing they are happy with dhw output and not lookin to alter house
Its a sealed system at the moment. I heard you can only run one bathroom on a combi
I have just got myself a flow cup.
is there a calculator for working out the kw needed for the CH. or can i fit the kw as the last boiler
sorry just realised what i said what athickly Ii am. i need to add up each room which will give me the total. Hammer, Head and hit.
lol, i was just having a school boy moment. I have also just found out that i can not us * to hide bad language. My apologies to the mods.
28 to 32kw normally enough general rule of thumb bigger the output the better dhw flow but remember you can t get out more than you put in ,use your flow cup
Even if you put in a combi boiler, the heating requirement should also be taken into account. If you don't you can end up with a boiler which is considerably oversized for heating.
Use the Whole House Boiler Size Calculator with the Domestic Hot Water Allowance set to 0. This gives the CH requirement. Make sure that the boiler can modulate below this - the lower the better.
If you want to check the output of existing radiators use the Stelrad Elite Catalogue. The page headed 40Δt is the correct one to use.
Reply to the thread, titled "Boiler swap" which is posted in Boiler Advice Forum on Plumbers Forums.
Britlee,
doitmyself,
