J
Jubbs
I have recently had a new Halstead ACE HE24 combi boiler fitted which has a fault.
The boiler will heat up the radiators and then stop heating when the water gets to the temperature set by the thermostat. But when it tries to relight 10 - 15 minutes later it fails and displays the number 3 (in the manual it states that this can be an indication of low gas pressure but the plumber is convinced that the gas pressure is ok - measured @ 2.7 m3/hr at installation).
The boiler will not relight until it and the radiators have cooled down and the pressure on the gauge is back to approximately 1.5 bar. To relight it, I then have to turn the dial to the reset position & then back to the temperature setting.
The plumber who installed it has came out twice to fix it, but both attempts have been unsuccessful. The part which produces the spark has been replaced and we have tried plugging it in to a number of different electrical sockets just in case the socket it was originally plugged into had reverse polarity or a bad earth.
I have also emailed Halstead's Service department and will update the thread if I get a useful reply.
Any help with this problem would be very much appreciated and I will forward any advice to the Gas Safe registered plumber who originally installed the boiler.
Jubbs 🙂
Your appliance is under warranty and therefore a manufacturers problem. Give them a call and they'll get someone out ASAP... Best that no one messes with it as it may invalidate your warranty, in my opinion 🙂
Thanks for your reply.
I wrote an email to the manufactures & they have called me to arrange an engineer to come and have a look at it.
The bit where you mention 2.7m3 per hour is the gas rate, not the gas pressure.
So the pressure could be low due to maybe a faulty meter governor
Keep us updated as to what happens
Is this boiler fitted with "upper water pressure switch" ie the pressure goes past 2.7bar and it cuts off? I'm sure I've had this on a few ferrolis b4. If that is the case the expansion vessel will no doubt need pumped up. It's not uncommon for them to come flat straight out the box considering they could be sat in a warehouse for a yr or so
